- Dec 26, 2016
- 2,016
I am in final stages of upgrading my Princess Auto bead roller, I copied most of the steps on Jere Kirkpatrick's video called "Building Gene Winfield's Bead Roller", except I opted for a manually operated hand wheel instead of making it power feed. the hand wheel is actually a 16" steering wheel that I bored to fit the drive rod where the crank handle would go.
I know you all like to see pictures and I'll do that when I get chance but my question to any one who has done this upgrade is, did you work with your bead roller by rolling it manually without a power feed for a while ? or did you decide to add a motor to it from the get- go? if it is electrically powered, what did you use, chain /sprocket? or a direct drive with a motor/speed reducer?
I know I may not get a lot of answers here since most may not be involved in sheet metal fabrication but if you do have any thoughts or comments I would be very interested to hear from you.
Ken.
Ken.
