- May 10, 2012
- 609
This is the planer I posted in the Ads for Sale forum, which I wound up buying. One of you other guys should have bought this, now I have to spend the time getting it fixed and working. Here's that thread:
https://www.hobby-machinist.com/threads/small-metal-planer-in-ca.69271/#post-583079
Anyway, here it is no the truck after I got it home on Saturday eveining:
I have two gantries and some come-alongs that I use for loading and unloading thinks like this, but unfortunately, the gantries were not tall enough, so I had to take disassemble it down to the main bed. in order to unload it. The ad stated that there was scoring on the ways, but it was much worse than I thought it would be. It looks like the machine was run completely without lubrication. This machine apparently predated the time when they figured out how to put oil troughs with wipers in the center of the machine to provide lube to the table. It had worn down so badly that on the back of the machine, the table rubbed the bottom of the clearance cut.
The rest of the machine was in pretty good shape, and it was complete, save for the lineshaft pulleys and shafts that would have ran it. It looks like from the holes drilled in the uprights that it had a motor drive on it at one point in time. Here are a few pics of the rest of the parts.
