- Feb 2, 2013
- 3,546
Thank you very much guys for your support and kind words.
i really appreciate it!!!
thank you all!
thank you all!
Wow Nice Score!
It might be one of the early ones with a hydraulic drive? lots of info here: http://www.lathes.co.uk/monarch/page2.html
Thank you Jim,That is quite a motor. Congratulations Mike. !
Thank you Mikey,Wow, congrats, Mike! You're living the dream but this makes it what, 9 lathes? You have the disease really bad!!
Can't wait to see your patient up and running.
thank you very much Eddye,Wow Nice Score!
Thanks Greg, it didn't give a dc rating, but it may run on DCCongratulations on your new family member. Keep posting.
Did a quick search on Type TLK motors, were they a universal motor? Quite a beast. Could the gearbox be utilized for 3 ranges with the VFD? Probably not necessary with 5 HP though.
Great to see kids with new toys.
Greg
Thank you once again Doubleeboy, i'll be sure to check PM out.MG lathes are not that difficult to fix, Wards Leonard drives were used in lots of elevators, keep it original. The Moarch board at PM is your got to resource for experience of those who have been down this path before you.
Thanks Rgray, i love he look and can't stand to see her with a broken heart from sitting on the sidelines while other machines get to play!Nice. Just NICE!!!
Jealousy abounds from here!
Thanks Dave, i'm still on cloud 9!!!Your nose is going to be too high in the air for you to see straight ahead. You will need to walk backwards to see where you are going.
I'll be sure to look up their resources, thanks!Its a motor generator machine, The Sundstrom machines that were fluid drive look dramatically different and were not built as late at 1943, there span was very short maybe just a couple years. Got to love the looks of those round dial machines. Just in case you haven't gotten this far yet a MG machine has a AC motor driving a generator which then drives the DC motor. Its the DC motor and its tremendous touque that makes these machines so marvelous. Take out the DC drive and you likely will be left with a sad rememberance of what once was. Ratheon in Cali would only buy MG machines, said they were the best for maintenance, as of early 2000s they still had a boatload of em. Lot of MG enthusiasts on the PM board, Russ is a wealth of knowledge on em, he has had more than one.
Hi Karl_T,I have an almost identical machine.
That jack shaft arrangement does not look original to me. My machine had a 1:1 drive for high gear and then a 6:1 reduction for back gear. Your back gear looks about the same as mine.
I kept the back gear and mounted it to a 5hp 3 phase motor and VFD. the lathe has run this way for nearly 20 years now without any trouble at all. BTW, VFDs were EXPENSIVE back then.
Once you are done, you won't be using the other lathes for any job that fits in the 10EE. The machine is Soooo much nicer its just plain painful to use anything else.
Hi Ken,How about another film strip with the brush access covers open? And push it outside the door when the trick o treaters come by and turn it on. That arching would light up the neighborhood. Bad to look at, too!
Nice find Mike!
go look what robenz did to his good ideaHi nez!
i hope to have a pulse from the patient soon!
if i'm messing with a project, it usually keeps me out of trouble!!! (or gets me into trouble )
