- Jul 14, 2017
- 2,446
This evening i spent some time on my hydraulic press, pushing in wheel studs on the littles nivas rear axles, then i got busy assembling the rear calipers, greased the sliders, installed the new brake pads and they fit over the brake disc. I had a real plan about the axle housing but then i talk with couple of lada owners, and they changed my plan. Their argument was, Why would you spend the time and cost of reinforcing it when is the same as the Lada sedans, and you can buy one for 10$ in the junkyards they apparently don't bent easy one guy said that you need to lend it from a metre high loaded to bent it. And with all the rust that my has i'll be better off just paint it and put it back to use.
