- Oct 13, 2012
- 175
My CNC'd Sieg X3 came with a 3/4" tool plate with a 7 x 21 hole pattern that takes 3/8-16 bolts. As I work with the plate I'm coming appreciate the work fixture options it presents over a vice. One option being the repeatable setup of soft blocks for fixtures. I was curious if anyone has seen or knows of a source for purchasing 3/8-16 threaded pins that can be screwed into the plate holes and presents a smooth precise 3/8" profile to butt vices or fixtures up against? Should I even worry about the smooth profile, or would the threaded rods that came with my strap kit be just as reliable?
If I had any skills, I would try turning the pins on a lathe. There are two problems with this. One, I'm a newbie with fledgling skills. Two, my 9x20 lathe was purchased completely stripped down for a CNC conversion by the original owner, and I doubt all the pieces are there to restore it to manual function.
-Freeman
-Freeman
