Near certain a McCroskey, the best. Tough and slick at the same time. The flange is turret lathe, but more than one has pulled his engine lathe compound off to mount one. Mill a plate to regain centerline, tap that 4 hole pattern and go to town. Others cut the flange down and T-nut remainder. Easy production boost, and less exercise hoisting rather [less] beefy Aloris or Dickson all day. A decent lathe is not set to have just one set of toolholding, if your work varies. Being able say, turn-bore-chamfer-part off, with 2 simple motions one hand never leaving cross slide handle; vs operate lever-pull holder- turn behind you and switch holders- replace and lock must be 4x time involved.
I'll bait with the avatar statement, all in fun. If you are "Making scrap at ludicrous speed" now, imagine how much time will be saved!
JK of course. That was last offered Sept 2019. Still have it?
