4 jaw chuck mounting
Nigel123
Dec 23, 2019
92
After owning the lathe almost 20 years discovered the 8 inch 4 jaw chuck is only bolted on (no recess machined)
In my defense I seldom use it took it apart to clean it for the first time (I think getting old)
I set it up to machine it, the run out is about 0.0005 thou but I noticed the countersunk cap screws are set deep
there is only about 3/8 inch of meat left so if I machine 3/16 off its getting a little thin
I have come up with some options
Leave as is
Bolt and pin a spacer and machine it to fit the recess in the chuck
Hope I explained this okay
what are your thoughts
There's nothing really wrong with having no recess on a chuck mounting, especially with a 4-jaw
Why make more work for yourself?
As long as the bolts are tight you should be fine; 5 thou runout is not bad- or did you mean 5 tenths?
-Mark
.0005" runout is about as good as you will ever get it, and the 4 jaw does not care so much about running true. I would make sure the fasteners are holding the chuck tight to the spindle, and then leave it alone. I understand you have only used the 4 jaw for the last 20 years??? Well then, maybe you are also good for the next 20...
-Mark
5 tenths, not 5 thou'. Even better...
Thanks for the replies advice
Not sure if it was acceptable to run this way and have avoided machining cast
Had it setup to do when I noticed the thickness and decided to post for answers
Very happy I did and grateful for the advice
My day is suddenly a lot brighter thanks Nigel
