• PHISHING SCAM attempt TARGETING HOBBY-MACHINIST members. It has been brought to our attention that a pop-up survey is soliciting userfeedback from H-M members. In exchange for survey information, the user is given an opportunity to win a prize if they pay for shipping charges. This is NOT a Hobby Machinist program, survey or contest. DO NOT click through the links. Close your browser immediately and restart your computer. Clear cookies, cache and log back into Hobby Machinist. Again, this is NOT a Hobby Machinist contest or survey - IT IS a PHISHING SCAM attempt to get your credit card information.To close this notification, click the "X" in the top right corner of this box.
4 jaw chuck
rzw0wr
H-M Supporter - Gold Member
Jun 18, 2019
133
I have a Bolton BT-1022 lathe.
This lathe is discontinued.
I can no longer get parts for it.
I would like to get a 5" 4 jaw independent chuck for it.
Does anyone know of a chuck that will work or that I can make work?
Thank you,
Dale
Latinrascalrg1
Dec 9, 2016
1,130
That shouldn't be a problem once you sort out the type of backing plate you will need to make it happen. You do the final faceoff and turning of the back plate mounting shoulder to match the 4 jaw you decide to buy on the lathe it will be mounted to.
rzw0wr
Jun 18, 2019
133
These are pictures of my lathe mount and the back of my chuck.
The chuck is held on with the 3 nuts on a disk that rotates a little to lock the bolts in.
Latinrascalrg1
Dec 9, 2016
1,130
Maybe start here to find a backing plate that matches the measurements of your current plate and then look up the chuck it will fit on the same site.
rzw0wr
Jun 18, 2019
133
Next question.
How do you remove the backing plate?
Mine appears to be press fit on.
Dale
Bob Korves
H-M Platinum Supporter
Jul 2, 2014
7,326
Next question.
Dale
The three bolts around the outside pattern appear to hold the chuck and back plate together. Also look at the front face of the chuck for fasteners holding it together. Perhaps show us a photo of the front of the chuck. My 'guess' is that it is just the three bolts on the outside circle. Sometimes the fits are tight and lubricants have dried in the mounting surfaces. They do not often just fall out, and getting them cocked can also make them stick while removing the back plate. Look at what is going on there carefully, don't just reach for a bigger hammer...
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
6,390
Lathe chucks aren't normally a press fit only on the backplates. They always use fasteners. At least I have never heard of or seen that. Like Bob said the 3 bolts should be holding it on & could just be a tight fit.
You'll most likely need to make a new backplate including the mounting pins. I'm not sure what the name for is for that type of spindle, if there is one, but they are commonly found on asian import mini lathes. I have never seen backplates for sale other than if you get a replacement part from a manufacturer/distributor. Doesn't mean no one sells them but I have never seen them.
Stefan Gotteswinter showed him making a backplate for his old lathe which had this type of spindle. IIRC he doesn't really cover much on how to make it, his video is more about how he made his (features).
Bob Korves
Jul 2, 2014
7,326
Next question.
Dale
epanzella
Apr 8, 2013
1,272
Check the other side of the chuck for fasteners or threaded holes designed to push the backing plate out. They might be under the jaws. If none, it should be easy enough to make a puller. Use a disc bigger than the chuck that will bolt on with the 3 big center bolts. Tap the ouside of the disc for 3 bolts that can pust against the chuck to pull out the backing plate. If you play your cards right, you can use the same disc for your new backing plate.
Choiliefan
Jul 13, 2017
316
rzw0wr
Jun 18, 2019
133
Yes it is.
I tried to order it but it is not available.
The lathe is out of production.
I just found out what the back plate on a chuck was.
I was thinking the the stuff on the end of the shaft was the back plate.
I think I can buy a 4 jaw chuck and make my own back plate.
Thanks for all of the replies.
Dale
AdBlock Detected
I've Disabled AdBlock
