5/8 x 11 Thread Wrong
jocat54
Dec 25, 2011
546
I have an Enco 12 x 36 lathe and just found out that the chart for 11 tpi is wrong:apologize:
I was making an arbor for a project and needed a 5/8 x 11 thread on the end of it. Set the lathe per the chart, in a hurry and did not check the scratch pass and proceeded to cut the thread. Store bought nut won't fit so get the thread gauge and check the thread---NOT 11. Double and triple check the setup from chart--everything is right.
I did not check other sizes from thread gauge, I was tired so locked up the shop.
Tomorrow I will check the other sizes with thread gauge and maybe figure out what is wrong.
jocat54
Dec 25, 2011
546
Well I feel pretty stupid--going claim a senior moment:grin:
I did not read the chart very well at all the times I looked at it.
It calls for 22t gear not the 24t that is normally used on it--now I have to find my change gears.:)
projectnut
Apr 14, 2014
1,170
It's a tough lesson to learn, but we've all been there a time or two. Many years ago I was making a back plate for a lathe chuck. The internal thread size was 1 7/16-12. Unfortunately I grabbed the wrong gear and threaded it 11 1/2 tpi. Whoops. In this case I was able to bore out the threads press in a bushing, pin it in place, and try again. I now put the chuck with the fancy backing plate on the rack in plain sight to remind myself to double check my setup BEFORE I start to cut.
rdean
Feb 2, 2014
377
I did the exact same thing last week but I didn't know what was wrong until now.
Thank you
Ray
Eddyde
Staff member
H-M Platinum Supporter
Oct 13, 2014
1,705
When I read your first post I thought "it's probably the change gear" Don't ask how I knew that, LOL
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
5,223
I have a 5/6 - 18 tpi stainless steel stud that I made. It's a beautiful thread but no nut to match. Is wasn't that the change gear that was wrong.......the wrong gear in the old noggin.
BROCKWOOD
May 26, 2017
713
Mine doesn't even list the 11tpi option - thinking I'll check to see what gear would give me that option. All of my mill accessories seem to call for that exact thread.
AdBlock Detected
I've Disabled AdBlock
