- Feb 7, 2013
- 2,481
E-Bay has 500 ampere bridge rectifiers available from the far east for a little over 50 US dollars and 200, 300, and 400 amp bridge rectifiers for correspondingly
less money. I went with the biggest rating one because it will be used for rough service for welding. Anyway, I mounted a heavy aluminum plate an inch thick
to the back of the rectifier with some silicone heat transfer goo and bolted a large heat sink to that with more goo of course. The biggest effort was so make
up a set of cables to wire up the rectifier. Also I made a large smoothing inductor to add to the secondary circuit. I'm using an old Forney 180 amp plug in welder
so had to machine tapered plug and socket ends to fit to the welder and existing welding cable. To my amazement, there is a huge difference between the old
Forney on AC and the Forney with the DC adapter rectifier and inductor. It produced nice welds on both straight and reverse polarities. Also I experimented
with leaving out the inductor and found that it was helpful in making smoother looking welds. I also have an old Miller Generweld 130 AC welder that I would
like to try this rectifier set up on. I need to mount the inductor and rectifier together and add a carrying handle to it and I will consider this project done.
