56C mounting flange drawing
John_Dennis
Mar 5, 2014
381
Does anyone happen to have a drawing of a 56 C mounting flange, Google is only providing false links.
Thanks
-JD
That is helpful but I was hoping to find the dimensions of the bolt spacing on the other dimension not across the center.
I believe that is listed as the “2F” dimension if I am not mistaken.
Cutting oil is my blood.
Are you referring to X/Y dimensions of the flange bolt positions? If so, I have never seen a drawing showing it that way, you will need to use some trig to figure it out from the diameter dimensions given.
I believe they are square at 4.15425".
That is if my math is correct.
The diagonal of a square is 1.414 x the length of a side. Divide the diagonal by 1.414 to find the bolt spacing.
