56Y motor frame
martik777
Apr 19, 2011
1,135
Any thoughts on adapting this frame size to a 56H?
Looks light duty to me but I could weld a heavier plate to it to fit the mill's mounting plate.
I can't read the name plate. I suggest avoiding an open motor in a shop environment. That looks like a motor for use in a fan system - often the fan that it drives is intended to provide cooling for the motor (so there will not be a cooling fan built into the motor).
I suggest you look for some sort of a closed motor - at least "open drip proof". Used motors are common and cheap - I suggest you can do better.
Hi martik,
you may wish to look towards a TEFC motor for shop use- it will last longer than an open frame motor.
(Totally Enclosed Fan Cooled)
