[4]
VN 7 1/2 DIVIDING HEAD
[3]
[10] Like what you see?
BROCKWOOD
H-M Supporter - Gold Member
May 26, 2017
523
Several people told me not to dismiss the Van Norman 7 1/2" Dividing Head. So, when I made an offer on ebay? I won. It came with a tailstock - but shy 2 indexing plates, a few bolts, etc. Show off / document yours here! I was missing 1 of the nuts that allow rotation between the base (mount) the main body. I happened to have 1 that is large enough to require the same size wrench to loosen / tighten as the other 2 stock nuts! Gonna need a spring clip to hold the indexing plate on. Also need a screw to have a complete set of 3 for mounting the indexing plate. So I ordered those in a longer length. The simple indexing plate also uses 10-32 screws in a longer length - but with a slotted head ........... I'll switch those to allen head while I'm at it.
On arrival, mine didn't have a proper backlash. It was repainted all together. Some disassembly was required. Now the backlash is minimal & she rotates beautifully! Needed parts are anxiously waiting their turn on the lathe! Show & share what you have!
Jason Annen
Jun 6, 2015
254
My 7.5" is complete. I made a fixture to clone the DH plates, it's a time consuming process though. Chances are you won't be able to find them.
BROCKWOOD
May 26, 2017
523
I have a few options for making them. I am certain they will be time consuming though.
BROCKWOOD
May 26, 2017
523
I found the 47 - 66 plate. Offered just more than I care to pay - but less than 1/2 BIN. I can make em for myself before I pay what some sell for.
BROCKWOOD
May 26, 2017
523
So far $75 per indexing plate is what sellers hope to get. It's called supply & demand. Snap-On, John Deere & Mercedes know this game well. So much for demand for VN stuff as there really isn't any. I'll make my own indexing plates at this rate. I did make my own indexing plate retaining clip for this lit'l 7 1/2 out of a fender washer. I cut the inside diameter, beveled it & then cut the slot. I debated over the order of operation as can be seen in another thread here https://www.hobby-machinist.com/threads/an-order-of-operation-question.73620/#post-617483
The end result:
Now what to do next? I loathe the idea of collecting VN noC collets at $30 each. Think I'll just get a chuck for it.
gi_984
Dec 13, 2012
457
"Think I'll just get a chuck for it."
I've got one on my shopping list for the 10 inch DH. Looking for a suitable one right now. Per the VN literature they recommend no bigger than a 6 inch.
Did VN recommend a specific size chuck for the 7 1/2 DH?
EDIT: Had it wrong, looked up in the VN accessories catalogue. Recommend a 4 inch chuck.
Did not see a recommendation for the 10 inch. But the factory did not offer a chuck bigger than a 6 inch in the catalogue. So I assume that was what they recommended.
BROCKWOOD
May 26, 2017
523
4" is recommended. Got 1 on the way.
gi_984
Dec 13, 2012
457
Is it a VN brand chuck? Please post pictures of how you attach the chuck.
BROCKWOOD
May 26, 2017
523
Will do. It has an adapter to screw on to the DH. Pretty sure it's gonna take a NMTB 50 Adapter for the 10".
gi_984
Dec 13, 2012
457
Thanks for the picture. Interesting. Looks similar to the pin set up VN used on the 10 inch DH. I've only seen pictures of how a 3 or 4 jaw attached to the DH. I did print out pictures from a machinist who modified a three jaw to fit. I'm planning on doing the same since I can't find an original VN chuck in good condition.
BROCKWOOD
May 26, 2017
523
Adaptor screws onto chuck & onto the 7 1/2" DH.
Any info you can share on adapting a chuck onto the 10 Vertical Swing DH would be great!
gi_984
Dec 13, 2012
457
"Any info you can share on adapting a chuck onto the 10 Vertical Swing DH would be great!"
Will send you a message with the info. Can also make photocopies and mail to you. Don't have them on digits.
BROCKWOOD
May 26, 2017
523
Well, I've bought what are called double sided indexing plates no 371 & 372. They only top out at a 49 hole bolt circle. It will be fun to see what I have in mind for them!
BROCKWOOD
May 26, 2017
523
Just cutting to the chase: 1/2" thick double-sided indexing plates really aren't a good solution - unless you are fine with milling 1 side off. My idea was to mill the center thickness only so that the plate would fit. But then, how to add the spring clip? The plate is too tall. But then how to advance the indexing pin beyond it's original reach? Just livin & learnin.
gi_984
Dec 13, 2012
457
How much thickness wise do you need to reduce? If you mill an equal amount off each side but leave just enough to engage the pin it might be doable. The pin just needs to enough to locate. It really isn't resisting any force. That is if you lock the spindle for each cut.
I'd make a paper template with the numbers on them before cutting. Mill each side evenly (if enough "meat") then surface grind each side for a good finish. Then use the pantograph to replicate the numbers. You could hand stamp the numbers also. Just harder to make it look neat.
BROCKWOOD
May 26, 2017
523
gi the pin holes sure seem deep enough to allow for that. An 1/8th off each side would bring them down to the desired 1/4" thick. Thanks. I have number stamps. Worth a try. Pantograph sounds like another fun project too.
BROCKWOOD
May 26, 2017
523
I kept my "Indexing Plate" search on ebay just to see if the 1 47-66 plate I found might get reduced to a more reasonable price. So many of the plates listed have so little information. So I made a chart & also made note of the 4 7/8" overall size & 1 1/2" center hole.
I'll add to the chart as info comes along.
286856
I found a generic listing that seemed more hopeful than modifying the plates discussed earlier up above. Made a fair offer & won. My cup runneth over.
286864
All of these fit the Van Norman 7 1/2! So I now have my full set of the correct 18 - 37, 38 - 46, 47 - 66 + an oddball & 4 extras!
The extras are 1 x 38 - 46 & 3 x 47 - 66. $40 ea shipped in the lower 48. PM me if interested.
BROCKWOOD
May 26, 2017
523
Update. Sorry, I don't know how to edit my post. Only 2 x 47 - 66 remain.
[6]
[5] [7]
