7x12 hf lathe upgrade question
D
Douglasr
Forum Guest
Register Today
Guys, is upgrading the headstock bearings to taper bearings a worth while investment?
I would only do that upgrade if the OE bearings were worn out and ready for replacement. I would not invest the time and effort into that unless the bearings already needed replacement.
Bob
I would say it depends on the work you are going to do, and what accuracy you want.
Ball bearings are not designed to support any significant axial loads. And I cannot speak to the quality of the bearings in your HF.
I replaced the ball bearings in my MM 7x16 and saw and immediate difference in smoothness and accuracy. Install wasn't that big a deal to me. YMMV... :)
Bill
Did you check the runout in your lathe? Usually these mini lathes have incredibly small runout for their price point. The indicator barely moved when I checked mine.
Unless something was broken, or there was noticeable runout, I would probably leave it alone.
Chris
