- Nov 16, 2011
- 275
I have motor from a residential elevator that I need to get wired up. The motor is 220VAC, single phase, 1/3 HP and runs at 1750 RPM. The motor includes a heavy gear reduction unit with output to twin sprockets. And at the other end of the motor is an integrated brake that prevents the motor shaft from turning until power is applied to the windings. Since this is an elevator motor, it is reversible and was originally controlled by a simple toggle switch.
The unit was recently removed from a neighbor's house as part of their remodel. It has been working fine in service for well over 50 years. For anyone interested, this is a Shepard Elevator Co from Cincinnati, OH and I believe the elevator was known as a HomeLift. It is a chain driven, single person (350lbs max) capacity elevator.
Please see the attached drawing for the wiring. I have 4 Red wires and 4 Black wires to the windings. Two Red wires are connected to each other and two black are connected to each other so I'm left with two Red and two Black to play with.
There are also 7 smaller wires going to the brake part of the motor. I believe these need to be energized to allow current into the larger wires for the winding.
I haven't tried to open the motor casing, but I can see a centrifugal switch and No starting capacitor.
I did try applying power from L1 to a Red wire and L2 to a Black wire. Tried all combinations like that but nothing happened. I obviously need to get the smaller wires near the brake involved.
Please let me know how to wire this motor.
