[4]
8mm female square socket?
[3]
[10] Like what you see?
PHPaul
Active Member
Dec 5, 2017
244
The collet draw bolt (proper nomenclature?) on my Grizzly mill has an 8mm square head. The provided 8mm open end wrench works, but a T-handle socket would be MUCH faster and easier.
I've searched fairly extensively for an 8mm female square socket without success. I'd be happy to make my own if I could find the material or a 1/4 or 3/8 drive socket.
Sources?
I did notice that the T wrench for my acetylene tank is REAL close, I could possibly buy one of those and file the socket out to fit. Tedious, but doable.
Ken from ontario
H-M Supporter - Silver Member
Dec 26, 2016
987
I good square file would make an easy job of widening that square hole, that's the route I would take because it is as you said doable and since I've done it a few times I know it'll work. just take your time filing ,file facing sides together ,measure frequently. good luck.
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
3,898
Try a 3/8" 12pt socket or box wrench. One of my 3/8" box wrenches fits a .314" square snugly.
PHPaul
Active Member
Dec 5, 2017
244
Ah. Hadn't thought about 8 point sockets. Ordered. Thank you!
kd4gij
Feb 7, 2011
4,799
I cut a 1/2" thick of 1" hex stock broached 5/16 square hole in the center it was a nice tight fit. and have a 1" wrench at the mill.
PHPaul
Active Member
Dec 5, 2017
244
Just a quick follow up:
I ordered and received a 5/16ths, 8 point, 1/4" drive socket. Picked up a cheapo 6" long 1/4" drive extension, TIG'd a Tee handle on it and All Is Well.
[6]
[5] [7]
