9x20 clutch
So where is this clutch located? is it on the carriage or in the headstock or the gearbox? I'll have to check my Grizzly G4000 if it has one but I don't think it does.
It does. Parts 210. 211. 212 in parts list.
Thanks @RJSakowski - I see it now. I never knew there was a clutch in there. So this is to protect the motor or the leadscrew/gears etc if you take too deep of a cut?
Yep but I've only ever had it slip on lowest speed and the next puller size up.
You will know when it happens as its very noisy.
Prior to it getting too weak it was kicking in many times on a large dia interupted cut.
