For what it's worth, the "pot metal" gear is actually "ZAMAK", as noted above. ZAMAK is an alloy of Zinc and Aluminium, and is considered almost as strong as cast iron. On most (all?) of the Asian lathes, the change gears are (I think) iron. Even the very low end HF machines are iron. They, all that I have crossed, are Modulus 1, 20 degree gears. I have made a few, to learn the process, out of aluminium. Eventually making a 127 tooth out of plastic for the Atlas/Craftsman at 16 DP, 14 degree.
Aluminium works well for the change gears. Actually, plastic works almost as well. My experiments with plastic were machined, not printed. I may get into printing later, but the process doesn't "speak" to me. A while back, I acquired both a set of 16 DP, 14 Deg and a set of Mod 1,(25.4DP) 20 Deg gear cutters. They were Asian, hence of questionable quality. They worked fine for Aluminium, I would question my skills to make any gears out of steel. I also acquired several sets of very small (<Mod1) cutters, to make gears for my models. That is more where my interest, hence skill, lies.
