9X20 Motor start issues.
Stockyj
Apr 1, 2017
9
I have in the past been able to start the lathe with the belt engaged.
When starting the motor it started to click off the mains throwing sparks out the rear of the motor.
I replaced the Centafugul start switch thinking all would be good but still is similar. If I start with the belt disengaged it is about 90% good start.
Has anyone had this issue is it capacitor or maybe the motor??
Z2V
H-M Platinum Supporter
May 10, 2017
930
Have you checked the bearings?
markba633csi
Apr 30, 2015
4,713
It's possible the start capacitor is failing (shorting internally), you could try a replacement cap but my hunch is you have a winding problem as RJ mentioned above
-mark
Stockyj
Apr 1, 2017
9
Problem has been fixed it was a dud Capacitor Thanks fo all posts.
AdBlock Detected
I've Disabled AdBlock
