Every part is now mounted in its position. Waiting still on the pulleys. Maybe tomorrow. I can't even start on the clutch assembly without them. Sigh!!! Bob, does your lathe have the nylon 80 tooth drive gear? I have spares if you blow one.
I have a friend at Lincoln laboratories. He brought these plugs to me at lunch. They are not your normal 9VDC connectors. They are rated 40VDC @ 10 amps. Now I will be able to easily disconnect either the motor or the Power supply at will.
