- Apr 23, 2011
- 2,476
Point and shoot camera charger for my Canon power shot may be not working?
I have an original Canon battery NB-4L and an aftermarket one as well. I cant get either battery to take a charge. They are 3.7v and the charger is putting out 4.1v on a digital multimeter. When you plug the battery in to the charger the green LED used to change to red and then after a few hours it would go green again showing it had charged. Now when I load a battery the LED stays only green. Left it charging overnight but battery still flat in the morning. I can measure the voltage at the contacts with the charger on and the green LED on but its not charging for some reason. Is it possible I have 2 crook batterys at the same time? Or do you think the charger is the problem? Seeing as how the red LED not working anymore.
Cheers Phil
Cheers Phil
