A Little Mistake This Morning
In my experience you end up sitting on in too long but I used butane and didnt really enjoy the process. I'm sure people get good at it. They say Map gas will get it there quicker. I just love tig welding aluminum to much to really worry about it. Once you solder that stuff on you cant weld the area. Seems to make a pretty strong joint though.
In the case of my part, getting there quicker probably wouldn't have been a good idea. :) On heavy sections the extra heat might be helpful though.
I've used MAP on silver brazing where the part was heavy enough to need it.
One of the reasons I decided to try this stuff is that I don't know how to weld. I think this stuff is good: I just need to improve my technique.
Seeing as this is a machining forum, not a welding forum i will have to suggest the part be made out of one homogenous block of aluminum with intersecting drill holes ;-)
If I had a mill, I would have done that.
When welding a common technique to battle heat soak and the related issues is to heat up the part to the required temperature as fast as possible.
i hope you realized i was kidding around right? It made me think about doing it as one piece in a four jaw. After thinking about it I decided to practice my Tig welding more.
i have used that aluminum “welding” rod before. With a small part like that i think if i blinked, id wonder where it went.
So here's Rev. 2, machined from 416 stainless instead of aluminum, and silver brazed together. I'll have to practice
my aluminum brazing but not on parts that matter.
