I finished the base for use on my granite surface plate.
I put a reamed hole in a steel block to hold the push pins square while I ground them.
All four push pins are installed.
I drilled pockets to hold the spring.
The spring is installed. It is the stiffest one I could find. I think it will work just fine. ( the indicator won't overcome it). It is pretty stiff.
Here is the finished base. I will make adapters for the indicators and for a scribe.
Here it is on the granite plate. The mirror finish lets it slide really easy.
I'm going to repeat one more time. With proper use , there is no danger of any damage to the granite plate. I am perfectly satisfied with this project.
