The winter 19-20 project is now in the garage. 1979 GL1000 that had gone through a period with full Vetters and then a poor rendition of a cafe with 7/8" pipe clamped in each handle bar clamp. A chunk of foam (no seat pan) for a seat. Lucked out and gathered most of the missing parts pretty quick. This is my first project bike that actually ran (although very poorly and pouring fuel out of the carbs) when I got it home. It does have ~2 year-old tires and a licely coated tank. All plastic is there although one side cover is broken (I have spares). Missing a muffler, but I have a fairly good '78-'79 left from the Hunley build.
Right now, the carbs are apart for thorough cleaning/rebuild along with the rear brake system. After they are back I will do the front brakes (at a minimum swap the calipers back to the correct sides) and front forks.
Oh yes, I've already changed the belts - before it was ever rolled over!
