- Jun 22, 2016
- 280
I finally got my new 8" Vertex RT and a new 7.6" 3 jaw. I immediately set the RT up on my Jet 9 x 49 mill. All dialed in and gave it a try. It works! There is very little if any slop and the locks hold well. It is a bit stiff when the worm is disengaged to manually rotate. I had to modify 3 Tee nuts to fit the RT slots. I clamped a block of aluminum to it with 2 strap clamps. The RT only has 3 Tee slots so choices weren't huge. I bored a hole and then off set to do 2 partial archs leaving about a 1/4" thick wall. Once again I learned that I should have done a detailed drawing defining the stop start points in terms of angular swing. Now I'm pretty sure I want to figure out how to make fixed stops. Having a DRO was a great help but the result wasn't perfect, not bad, just slightly less than ideal. After spending about 4 times as much time as it should have taken me it was done and on to the next trial.
I attached the chuck after making a new set of Tee nuts to fit the slots and the cap screws provided with the chuck. I can see now that this setup is going to be very limited. I don't have enough Z-axis. From the bottom of the drill chuck to the top of the jaws, with the table all the way down, I've only got 2.5", The drill chuck to the spindle is 3.25" That means 5 3/4" when using a collet. The chuck is 4 3/4" high to top of jaws and the RT is 4 1/8".
Very limiting. Seems like I need to add a riser to be able to machine anything of any size.
Have any of you done that? This is a Bridgeport knockoff mill.
