- Mar 3, 2013
- 1,448
Edit: Never mind duplicated what Mark said above....
One error: It won't shut off; need to move T2 over and connect to T4. Only white (neutral) should be on lower right terminal.
Also (although not absolutely necessary) P2 could be moved over and join T3 on the upper left terminal.
Mark
ps You'll notice this hookup doesn't break the black hot wire when the switch is off. Not a problem really, but it bothers some people. You could in fact
swap the black and white line wires and the motor wouldn't know the difference.
