- Jun 10, 2019
- 532
I need to do a bunch of drilling ops in 304 and 303 SS round stock in a lathe. Yes, these alloys are different from a machinability standpoint; I'm hoping what works for 304 would work for 303. My drill chuck max capacity is 5/8", so would need a reduced shank bit or a 3MT tabbed shank drill. I will be using the drill to rough out the ID to 3/4" diameter; will bore to final diameter. About all I know for sure is that I should be looking for a 135 degree drill point angle and a good grade HSS minimum. That's where I get a little stuck - all the HSS on McMaster is 118 degree. Being a hobbyist: cost is also factor. Full carbide drills at $275+ on McMaster is not happening.
I'm looking for 3/4" because i can't take big bites with a boring bar on my particular machine. GIven the amount of drilling: worth getting 3/4" vs. using my 1/2" drills (I've also managed to smoke a couple of these 1/2" drills and my re-sharpening skills require...sharpening).
So...what's your favorite flavor of drill for this sort of thing? And while we're here - suggested S&F?
