- Feb 14, 2018
- 12
This is my problem:
My local machinist says he does not have the means to fix or duplicate this, particularly the blind corner.
It is aluminium. I need to fix about 30 of them with the same problem. The original part is discontinued and out of stock.
I have a few ideas, if you kind folks would indulge me in the pros and cons of each, or just tell me how. heh heh.
1. build a mold, recast it.
2. fabricate a new one from a block of aluminium.
3. machine flat, then perimeter weld in a new set of teeth from a piece of aluminium rack gear.
4. machine key ways in it and fit a piece of steel rack gear. (although, I think this part may be somewhat sacrificial).
5. tig fill in the missing teeth, then re-cut them.
6. try to partial cast it somehow
Thanks in advance.
If there is a better forum for this question, please redirect.
Thanks in advance.
