I have a AL/CE500D power feed I purchased for my 20” Enco mill/drill.
As you can clearly see circled in green the bracket that fits the table doesn’t fit very well at all. Should I machine this bracket to fit the corner of the table nicely?
Second question, circled in red are the 2 bolts that hold the power unit onto the table bracket. Should I drill and tap the end of the table and install some longer bolts to help hold the unit to the table securely?
