Aluminum Meat Mallet
tredding
Apr 23, 2022
11
I made one in high school, about 1965. My sisters and daughters have used it and would like one for Christmas. So, as a first project, I plan to make ten of them. I have a 7X14 lathe which should manage the handle, though the taper may be tedious to make. I have a verticle mill that can easily handle the shape, and drilling and tapping for the handle. But I don't recall, now, how I made the strike pattern for the ends of the hammer. Is there a "V" milling bit?
Recapturing high school machining skills is fun, at least I think it will be.
All guidance will be greatly appreciated.
mmcmdl
Staff member
H-M Lifetime Diamond Member
Jan 31, 2016
8,395
Angle cutter on an arbor or just grind up a tool and use a flycutter .
markba633csi
Apr 30, 2015
8,033
I'm thinking maybe a flycutter with a bit ground to shape?
Ooop Dave got it first
The mallets I've seen have pyramids, so you'd do two sets of cuts at 90 degrees to each other
mmcmdl
Staff member
Jan 31, 2016
8,395
Yep Mark , I think woodchucker was asking about a flat knurl yesterday . The fly cutter would be the easiest I think . Being aluminum , shouldn't have any issues . :encourage:
mattthemuppet2
H-M Supporter - Gold Member
Sep 28, 2013
3,453
I have a bunch of 90deg endmills. What size do you need? Let me know and I'll send you one in the post
mmcmdl
Staff member
Jan 31, 2016
8,395
More than 1 way to skin a cat . Tilt the head on the mill if possible . No special tooling needed .
tredding
Apr 23, 2022
11
Right. pyramids. I just added another photo to show the pyramid pattern on the opposite face of the hammerhead.
ErichKeane
Making scrap at ludicrous speed.
H-M Platinum Supporter
Aug 3, 2017
2,022
Absolutely this, tipping the head is perfect here. The 90 degree cutters have the problem of not cutting at the 'center' and sometimes leaving a poor finish there. If you're willing to do the math as far as offset up/side/etc, just putting it in the vise at a 45 degree angle works in 2 setups.
tredding
Apr 23, 2022
11
Yes, one side is straight ridges and the other side pyramids. I just posted another image with a gauge laid up againts the head with the pyramids.
woodchucker
H-M Supporter - Silver Member
Nov 25, 2015
4,934
not me... you got me and some other member mixed up.. Is that why you never get me the stuff I am looking for... you been shipping it elsewhere? :)
AdBlock Detected
I've Disabled AdBlock
