- Aug 5, 2018
- 259
Hello again,
Hope everyone is well.
A popular gal on YT with blond hair recommended throwing out the grey wheels that come with most bench grinders and going with 60 grit Aluminum Oxide wheels, which I must say, I obeyed. I did this primarily to get the most out of my tiny 6" bench grinder after learning quite a bit from another post of mine about wheels (thank you).
There was another reason as well. The wheel I had on the grinder was out of round considerably and using a star wheel (recommended on my other post) I was unable to true the wheel to the point where the grinder didn't want to shake, rattle and roll off the bench once turned off. It was horrible listening to it wind down.
Anyway, a new Norton 6" x 3/4" 60 grit Aluminum Oxide wheel came from Amazon today with the most deplorable plastic arbor sleeves to accommodate shafts from 1/2" up to 1" that I had to make an aluminum arbor spacer to eliminate the sloppy slack these sleeves provided which naturally led to a wobble I've never seen except for the town drunk and a horrible wind down to match.
Much to my amazement, my well fitting spacer turned to the exact size of the wheel hole and reamed to the exact size of the shaft didn't make much of a difference, the new wheel still seemed to wobble and the wind down was worse than with the old wheel.
Did I get a bad wheel?
Do I need to true it after installation?
I did check the shaft and without the wheel, it seems to run true with no discernible run-out.
What is going on here, any serious suggestions or advice will be greatly appreciated.
Mike.
Mike.
