- May 3, 2017
- 1,996
I made this chip shield out of clear plexiglass and some scrap aluminum. I did a lot of head-scratching before beginning the build. I tried to anticipate every conceivable application with regard to size of milling projects and safety. Once I zeroed in on these criteria, I came up with a design. The end result has a center panel and two 'wings'. The center panel also has upper and lower adjustable panels to allow for over-sized milling projects. The wings are connected to the center panels with hinges I made from 1/2" aluminum, and the rods were from a piece of leftover 1/4" brass rod (would've liked to keep that one, but I didn't have any scrap 1/4" rod available). The movable parts are secured with stationary threaded studs and wingnuts - no need to hunt for a wrench. The three-panel design allows for adjustments in essentially every dimension to accommodate small to large milling projects.
The unit is very sturdy sitting on the vise, so I'm still trying to decide if I want to add magnets to the base. I'm trying to avoid that if possible - I anticipate I'll be using this regularly for steel projects.
Regards,
Terry
Regards,
Terry
