[4]
Another clausing Dp
[3]
[10] Like what you see?
dlane
Sep 27, 2014
3,045
My new friend
Should be better than new DP junk when I’m done, CL $50.00 find still in truck , heavier than my Ti floor mod ,
It dose have the arc of shame but but made in USA.
chips&more
Mar 19, 2014
2,471
For 50 bucks??? YOU SUCK!!! I had to pay $450 on CL for mine. Great find! You will not be disappointed!
dlane
Sep 27, 2014
3,045
Should be a good one after some cleaning and ??. My Taiwan floor mod drills triangle holes, I’ll fix that one also.
dlane
Sep 27, 2014
3,045
Got it apart except the spindle it seems ok , I replaced the electric cord to run the motor it started rite up sounded good for a while then started to kinda howell I’ll prob bring it to a motor shop and have them check it out,
but it is a Howell motor I don’t think it should howell. I’ll fix the arc of shame with JB weld unless someone knows a better way ? . It’ll get cleaned up and painted, thinking of filling the collom with cement for stiffness what u think ? .
that’s it for now.
It is a mod , series 16 sc if that means anything
Silverbullet
Gold
May 4, 2015
3,420
If you have some grinding chips mix them up in the epoxy it be more realistic then old gray epoxy. Looks like it may be the bottom pulley causing the howling, it's about wore thru. Epoxy it will help that too. Oh I'd add a counterweight in the column with a pulley and sash chain hooked to the table to help adjust it easier. Ck Mr Pete on YouTube easy to do.
dlane
Sep 27, 2014
3,045
The bottom pulley is remains of the belt
dlane
Sep 27, 2014
3,045
How’s the best way to remove motor pulley without damage, there soaking in Blaster now ?
Thanks
RandyM
H-M Supporter - Commercial Member
Staff member
Apr 12, 2011
2,356
Thanks
This is the best way, along with being very, very patient. Any penetrant or oil and lots of time will work really well. Good luck. :encourage:
dlane
Sep 27, 2014
3,045
It’s still going to take some pulling /prying off the motor shaft , it isn’t going to fall off.
I don’t want to damage the pulley or motor, anyone try a little heat ?
rwm
Mar 25, 2013
1,517
Do you have a gear puller that will fit over it?(or make one) Put some load on it with the puller and tap the sides of the pulley without denting the aluminum. If the motor is shot, cut off the shaft and tap out the remainder from the pulley. Does anyone know if that motor is original? The motor on mine is labeled Clausing.
Robert
Buffalo21
Feb 24, 2018
93
I don’t like using a puller on pulleys (sheaves), I always try to use a bearing splinter behind the pulley, to put even tension on the pulley rim.
rwm
Mar 25, 2013
1,517
But doesn't that put axial load on the motor bearings? In this case they may be shot anyway so your idea is a good one.
R
Buffalo21
Feb 24, 2018
93
R
No, I probably didn’t explain it properly, I put a bearing splitter behind the pulley, then use a puller the pushes on the mtor shaft, while puller jaws, grab the bearing splitter. I just don’t use the puller directly on the pulley.
rwm
Mar 25, 2013
1,517
That makes sense.
How about this idea: lay two steel bars under the pulley with a gap to fit the shaft. Support the bars on blocks and then drive the shaft out with a punch or press. You could notch the bars for a better fit.
Robert
dlane
Sep 27, 2014
3,045
All cleaned up painted , all new bearings in the head, arc of shame JB weld filled filed smooth, new power cord,
.0008 tir on spindle taper, squirted some spindle oil in motor oil ports sounds good now.
I bolted it down to the rolling cart w/locking wheels. Still waiting on new locking collar 1/2” chuck to arrive and need a new 47” belt
RandyM
Staff member
Apr 12, 2011
2,356
Well done Dlane. Looks like you gave it a very practical and prominent spot in the shop.
rwm
Mar 25, 2013
1,517
Do you know the number of the spindle bearings in this?
Robert
dlane
Sep 27, 2014
3,045
I replaced mine with Timken p202kdd52 per the invoice, I had my bearings with me at the bearing shop.
The dp is on a rolling cart I mounted the 3ton arbor press and the Reed vise behind the dp so I can get them out of the way.
rwm
Mar 25, 2013
1,517
Hmmm. a search for that yields nothing? Even on Timken's site. I believe this may be a 6202 bearing.
Robert
dlane
Sep 27, 2014
3,045
Ya I had my bearings with me and they matched them , looking at the invoice again I left off a couple #s try this
P202kdd5217p, but 6202 sounds rite
[6]
[5] [7]
