- Nov 23, 2020
- 787
David,You might get some ideas here:
Moving PM1340 Lathe
This album of images documents what I went through to move the new PM1340 metal lathe from the garage into my basement shop. I did this entire process working alone, so I did lots of advanced planning. Click photo for details below the image.www.flickr.com
If I had your situation with stairs at angles, I would probably use an appliance/hand cart like this:
Remove the tailstock, motor, apron/cross slide, and strap what remains (bedways & headstock which weigh about 400 pounds) to the hand cart with the headstock facing down and resting on the sled. Two people should be able to maneuver that load down twisty stairs one step at a time. The headstock weighs about 180 pounds, and you’ll want a to align it no matter what after the lathe is set up on the stand, so you could remove it as well (if you don’t have a helper for the contraption mentioned above) and move the items separately. The bedway casting is the heaviest component.
You might get additional inspirations here.
When you removed our headstock, how did you grip it?
Would a rope through the spindle work, or would that put a dangerous side load on it?
Also, for the apron and cross slide removal, do you know of any threads that provide the how to? It looks to be pretty complex, especially the apron, as it requires removal of the control bar, power feed bar, and lead screw.
Thanks!
