Another obligatory New PM-833TV and PM-1340GT Ordered!
Aukai
H-M Supporter - Gold Member
Oct 4, 2016
5,753
Did you seal the chip pan to the bed well? Mine leaks.....
davidpbest
H-M Platinum Supporter
Dec 26, 2015
1,567
Looking great. Were my weight estimates close?
Christianstark
H-M Lifetime Diamond Member
Nov 23, 2020
593
No. I decided to silicone around the bed feet. Easier to cut and disassemble down the road if we move
Me and 3 neighbors were able to just carry it around and into the basement. Before we did it got a WD40 wipedown, removed all the cosmoline, and then wiped down with IPA to remove residue.
Christianstark
Nov 23, 2020
593
Got it here yesterday before I quit for the day.
Christianstark
Nov 23, 2020
593
A few more pics.
got the forward-off-reverse bar, powerfeed bar, and the lead screw reinstalled. Did a little file work in the key ways, and modified the clutch a tad. The original grub screw galled up the key way making removal difficult, so a drill and file helped me solve for that.
Christianstark
Nov 23, 2020
593
Noticed an issue with the compound gib. It seems when I attempt to adjust the gib with the screw closest to the tool post, the clockwise motion of the adjusting screw lifts the gib inside the slot, and causes binding. The lift is over a mm of travel. The vertical movement of the gib is all throughout the length of the cross slide.
Should the gib be pulled upward, away from the way, or should it be pushed down towards the way? Their only seems to be one scraped surface which holds the compound down to the ways on the dovetail, but the gib itself moves quite a bit up and down if both adjusting screws are loose.
An additional annoyance is when I adjust the gib so I have no or little side to side movement, the adjusting screw at the hand wheel is backed out as far as it will go, so as wear begins to happen, I will need to trim the gib at the narrow end so the adjusting screws can still work properly.
Not sure if this makes any sense, or if this will help but...
Here is the gib adjuster at the back side of the compound...It sticks out quite a bit.
And here is the other, almost touching the hand wheel assembly, I.E. no room to tighten beyond here...
AdBlock Detected
I've Disabled AdBlock
