- Mar 26, 2018
- 7,713
You used the phrase "good beer" referencing IPA.Pardon me, but that's a waste of good beer!
Sorry, I couldn't resist.
I prefer the golden fruits of Adolph Coors.
I know, my opinion is worth nothing
I found the same, but decided to make my own scraped gib with precise fit.This is causing the gib adjusting screw to have issues getting a purchase on the thin end of the gib.
I have contacted PM for assistance.
The way edge does not look straight? Is this a photo deception?Next shows me applying pressure to the thin end of the gib
I neglected to take photos and document the process which is a shame - I was frustrated and in a hurry. However, I basically followed the same process Keith Rucker describes in the video link posted below. His series goes on for 3-4 episodes, so watch the follow-up videos too. I did use cast iron, and finding a scrap of Durabar for this was probably the most challenging aspect of the project. I don’t have a surface grinder, so after machining the replacement gib, I did a lot of “hand honing” work on a surface plate with successive grits of sticky-backed sandpaper stuck down to the surface plate, hand rubbing the gib against the abrasive, and then grossly flaked it for oil retention. It’s not to NASA standards, but a heck of a lot better than want came with the machine. Hope this helps.Can you point me to a description of how you might have proceeded to make yours? Thanks.
The way dovetail is indeed sloped, but that is to accommodate a wedge shaped gib.The wedge + gib makes a straight slot to ride on the ways of the compound base. The gib it tightened by adjusting 2 screws at each end of the gib. loosen the thin side and tighten the thick side to tighten, and vise versa to loosen.The way edge does not look straight? Is this a photo deception?
I did not mean sloped. I meant straight. It looked bowed?.... so that a properly made gib would only be hitting a one points and so rocking.The way dovetail is indeed sloped, but that is to accommodate a wedge shaped gib.The wedge + gib makes a straight slot to ride on the ways of the compound base. The gib it tightened by adjusting 2 screws at each end of the gib. loosen the thin side and tighten the thick side to tighten, and vise versa to loosen.
I see what you mean. I think it MAY be a combination of the taper in the gib, and maybe a roll off on the way. Here is another pic that shows the gib referenced to a flat surface.I did not mean sloped. I meant straight. It looked bowed?.... so that a properly made gib would only be hitting a one points and so rocking.
