- Jun 2, 2021
- 41
I've been following this tread for the longest time. I think I'm just as exited to see you have finally received your mill.
It’s been a long wait!I've been following this tread for the longest time. I think I'm just as exited to see you have finally received your mill.
Check out this thread!So I’m thinking out how to best get this beast down the steps outside, and into the basement. Thinking I can break the machine down into several pieces.
It looks like I can remove the x and y together, and all I need to disconnect is an oil line. Thoughts?
also, thinking about removing the control box and motor for additional weight reduction.
latly, was thinking I can remove the head. Anyone have an idea as to how much the head weighs once liberated of its motor and control box?
Finally I can use a hand truck for the rest.
I did some file work last night and today, and the jaws are sliding much better. I just put the chuck and other parts in the dishwasher to run a rinse and dry cycle, and plan on wiping it down with some light machine oil, and re-assembling with way oil. I THINK the only thing that needs to be replaced is the 1 screw that was damaged when it was installed. I do hope they are able to just source that part, instead of having to wait for an entire chuck, and then de-burr it just to get to run smooth. Amazing what a little work with a few files can do.I'm sure Matt will replace it. That certainly looks like defects originating at the factory.
So a sure fire way to make new iron look like old iron? Run it through the dishwasher!I did some file work last night and today, and the jaws are sliding much better. I just put the chuck and other parts in the dishwasher to run a rinse and dry cycle, and plan on wiping it down with some light machine oil, and re-assembling with way oil. I THINK the only thing that needs to be replaced is the 1 screw that was damaged when it was installed. I do hope they are able to just source that part, instead of having to wait for an entire chuck, and then de-burr it just to get to run smooth. Amazing what a little work with a few files can do.
