Thanks Mark. Thats pretty amazing on the speed pot.
I took Alan Heffernan's advice from the VFD Panel pdf and cut & drilled outside with a mask. I also found a very good jig saw blade at Home Depot that boat guys use for cutting and repairing fiberglass.
https://www.homedepot.com/p/Bosch-3...eramic-Glass-and-Fiberglass-T130RF1/100194774
I ordered some electrical connectors from McMaster Carr to fit the power supply. Well they shipped the right package from 3M but they contained the wrong connectors. First time a problem with McMaster Car but it was 3M's fault, not McMaster Carr. So i'm waiting on the replacement connectors.
My Fluke DVM which I bought in 1979 finally quit working when reading ac volts. I guess its time to buy a new one. I always like to ohm out my wiring before I turn on the switch. I'm a real believer that components are good until you let the smoke and sparks out.
I'll post here to update on the progress of the install.
Jerry
Jerry
