I made my decisions. but first..... Since the grinder column is mounted permanently and finished, I decided to do some accuracy and squareness checks. Since almost everything adjusts, I can get as close to perfect in all directions as I want to work at. EVERYTHING flexes to some degree. And as heavy as this machine is built, you can grab hold of it and flex it a thou or two with some effort and that is over at least six to eight inches. This is not a problem because there is really no pressures or stress grinding tools. ( it is heavier and more solid than the Bonelle , and it works fine) Next I wanted to check my wheel arbor.
And ....holy runout Batman!! this thing has .004" runout. I removed the arbor from the motor and checked the motor shaft ..... .0005" runout. The 12 mm shaft measures .470" and my adapter measures .472" bore.
That is why there is .004" runout. Now I'm thinking I got to make a new arbor to get it perfect.... or wait!!!! .... I have two set screws , 90 degrees apart.... if I put 4 set screws , 90 degrees apart, I bet I could get this thing almost perfect. by messing with the set screws. By now I have been fussing with this mess for a half hour or so and started looking at the grinding wheels. THE GRINDING WHEELS AREN'T EVEN THAT ACCURATE! ..So What am I fussing about? I spent two hours on the computer trying to find one or figure a way to put an ER 20 collet chuck on this motor. But if I did , I would never get closer than a couple thousandths changing arbors in a chuck. I finally realized that idea is no better than what I already got and what I got is better than any grinding wheel , so I just wasted a whole afternoon fussing over .004" that is almost impossible to make much better.
Now..... what got me started on this whole mess, besides my extreme habit of being a perfectionist, ( which can be a problem when you try to do anything), Is I had a discussion with my good friend ***** ****** about grinding wheels. He mentioned if I put a wheel on and true it up by dressing it, I would have to dress it every time I removed it to use another wheel and put it back on again. And he is correct here. I did not care for this fact. Through discussion , we agreed that mounting the wheels on their own arbor and using a chuck to hold the arbors, this problem would be gone. That is almost true, and I have proven this theory on my Bonelle grinder , which has an ER 20 collet. When you put the wheel and arbor in the chuck, dress it, remove it, and put it back, it is close but not as good as it was. there is always a couple thousandths difference here and there. So to sum this up ... IT AIN'T GONNA GET NO BETTER THAN IT IS .... so I will leave it alone and be happy with what I have made. I may have to re dress the face, but not the periphery of the wheel as I don't grind on it ...much.
Now back to my decisions ..... about the collets for the air spindle. I have decided to get a 33 piece set of 5C collets by 64ths for the grinder and later I am going to also get a set of ER 40 collets for the other machines. When building a machine comparable to a $10,000 commercial machine, it deserves a dedicated set of collets.
