I agree with Mark and David, if doing it again, I would skip buying a kit. Something to consider with the Chinese parting blade holders, they are pretty bad if you use the P type HSS parting blades. The P type needs a groove at the top for the wider top section of the blade, or a shim of the appropriate thickness on the bottom section of the blade, and the bottom groove had a radius on mine that prevented the blade from seating vertically causing it to do poorly when parting or grooving. I modified mine to work better, but that is one area where you might want to skip the HSS blade holders all together that come with the kits and start with a carbide insert toolholder held in a #1 or #2 holder and then get a blade holder like the Aloris #71 or 77 when you want to move up to a blade style for deeper parting. The Aloris or Dorian might be better, but that is an area I am currently looking at getting rid of the standard style and going to carbide inserts.
