Any valve Guru here
stuarth44
Jan 22, 2020
197
I picked up 2 KA ME WA hydraulic packs used to control jet thruster pumps on A won bid @auction because nobody knew what they were, 2 for 200
about 5-6k worth each
They have a test stamp of 3500 psi,
now I am not an expert in this field
controlling my 3 rams and one motor through manual lever valves and flow through pressure compensated flo valve
the main valve block has 4 24 vdc solenoids, which I activate through a 24 volt battery, the idea being I can stop flo to the manual valves by switch, some of the ports I dunno what they are for, anyone have experience with these valves, thanks
LS is load sense usually goes back to piston pump to control the swashplate, or output of the pump
could I plug it, I have an inline flo control, pressure compensated
i don't know. I guess I would need to see a schematic for the valve and what type of pump you are using.
i saw a youtube vid I now know what it does, eventually will get it sussed, apparently it cut the pump press until the load is lifted, thereby power saving, but guessing you know this
thanks, i pushed air through ls on valve block, it came outon a branch leading to pump via a tee on top lo press filter. all done nows
pump was gear pump, blocked to ports and now it works fine, thanks
