Thank you ........ If you have some, I would be very happy to pay you for it. I downloaded the write up for the cross feed and the compound. I want to change my dials on the lathe to large ones. I am practicing the procedure on my X Y table on my tool grinder. The same procedure will be a great improvement to the table as well as the lathe. I have 1/2" screws for the grinder but the 716-10 LH screws for the lathe I can't find.Mark, I may have some, give me a little time and will look for it. It is new unused from Steve if I can find it.
Mark, did you ever contact Steve or locate the 7/16 - 10 LH acme screws elsewhere. I'm working on my SB 9" and just ran into the same problem. I can't find anyplace on the Swells website to order the Acme screw. Thanks.Thank you ........ If you have some, I would be very happy to pay you for it. I downloaded the write up for the cross feed and the compound. I want to change my dials on the lathe to large ones. I am practicing the procedure on my X Y table on my tool grinder. The same procedure will be a great improvement to the table as well as the lathe. I have 1/2" screws for the grinder but the 716-10 LH screws for the lathe I can't find.
Yes, another member had one and I got one from him. To get to Steve Wells, you need to email him. His email address is on the his website. Be patient as it takes a while to get a response. When I spoke to him last by email, he was making more.Mark, did you ever contact Steve or locate the 7/16 - 10 LH acme screws elsewhere. I'm working on my SB 9" and just ran into the same problem. I can't find anyplace on the Swells website to order the Acme screw. Thanks.
