I decided to take the carriage off to clean a little and inspect. I discovered my lead screw is bent. It's ~52" and when I rotate it it moves from just touching the lath to an inch and a half away from the lathe. Is this enough to do anything about it?
Also the double row self aligning bearings (1201 & 1202) that hold the feed screw and feed rod(?) in place are shot. The one oilier was plugged so I think that contributed to the failure.
