- Dec 25, 2011
- 10,505
I agree. While a set that has exactly what you think that you need would be better, single gears do show up as well as sets. AFAIK, the 101.07403 parts manual that is in Downloads is accurate in this respect. I am about to release Revision 8 but the changes are limited to cleaning up some of the text for better legibility.
Note that the full change gear set for a 101.07403 is 15 gears. It includes five gears that were always on the machine when it originally shipped. These gears are 20T x 2, 56T and 64T x 2. So the full set of change gears for a 101.07403 is 15 gears. Plus one spacer which should always be on the shaft containing the screw gear. Also, be sure that all of the gears that you buy have an "A" suffix to the part number. The original 10" and 12" change gears had part numbers of the form "9-101-nn" where "nn" is the tooth count. These were supplied on all lathes equipped with 5.8" diameter lead screws except for the 101.07402. These gears have a nominal 3/8" face and 3/8" hub length. The Revision "A" gears (part numbers "9-101-nnA"), still have a 3/8" face but the hub length was increased to 1/2". The original gears can actually be used on the later machines but will require two 1/16" thick double-keyed spacers to make up for the shorter hub length.
Note that access to Downloads is limited to donors because the expense of maintaining the Downloads section is a significant part of the site's monthly expenses.
