For those interested to buy, I comment on the lathe advertised as follows;
- The lathe advertised is not quite up to the level of quality of a tool makers lathe, in my humble opinion, but a good workhorse lathe for the hobby machinist and also a good entry level lathe for someone.
- The lathe is an older 9 inch South Bend model C bench top lathe, as the spindle bearings are lubricated from the top and not from the front of the bearing casting, as the newer lathes are.
- The electric drive motor belt pulley looks to be a larger diameter to that of my SB9"C lathe.
- The electric motor is not mounted correctly, most probably due to the pulley diameter having been changed (or the electric motor) and the same V-belt having been used. This is not a big thing to fix.
- The bracket that holds the electric motor and driveshaft pulleys is not of the swinging type, which when fixed onto the bench, will have to have tensioning slots cut into the bench to allow for the leather belt adjustment, from time to time. It will be a bit awkward to work with, unless another method of belt adjustment can be made and fitted.
- One of the gears is fitted to a shaft, which I don't identify where it goes, at the moment.
- The manual for this lathe can be downloaded from this forum.
- All parts for SB9C lathes are still readily available on Flea-Bay.
- The price is right!
An entry level Chinese made mini bench top lathe costs about US$ 2000.00, or more, so for a hobby enthusiast, this lathe will be a good entry level lathe to start with and minimal work to get her running well enough to make the metal chips fly. Unfortunately I live in Namibia, so delivery would be a problem. Overall a nice lathe, as advertised.
