- Dec 31, 2010
- 937
I have had the above tool holder for years thinking it is a large cutoff bit holder. The shank that would go into a lantern tool post is 1/2" wide, 1-1/4" high and 4" long. If it is in fact a cut off tool, the blade would be 11/16" or 3/4" high. The holding taper at the bottom is 1/4" wide and the oval tapered retaining bolt head is 11/16" in diameter and the straight clamping part is 5/8" long. The tightening bolt is 3/8" X 16 tpi with overall length of 1-1/*8". To use it in my shop would require making a large lantern tool post or try using it on my 7" shaper. Also special shaped bits. I would like to hear from anyone interested in this tool.
Have a good day
Ray
Have a good day
Ray
