Atlas/Craftsman 12x36" lathe...questions
Jason280
H-M Supporter - Gold Member
Mar 20, 2019
153
I lucked into a deal on a Craftsman 101-07403 12x36" lathe, and hope to start restoring it back to 100% condition soon.
First question, what is the model number of the comparable Atlas lathe? Hopefully, having both model numbers will make looking for parts a little easier.
Its in decent shape, just a little surface rust on a few parts. Good thing is, it has the quick change gearbox, and both 3 & 4 jaw chucks. Bad? No motor, which is an easy fix, and the tailstock is rusted/locked. I have it soaking now, but worst case is I have to pick up a replacement online. Do the 9, 10, & 12" models all share the same tailstock?
Gear wise, everything looks to be in very good shape. The QC gearbox slides, and the half nut engages and moves the apron. I need to replace a couple of the levers and wheels on the apron, but I have found those without too much trouble on eBay. One of the gears that slides in the top slot of the quadrant assembly has the wrong bolt, so I can't get it tight enough. So far, that's the only real gear issue I've found.
It does have a few issues here and there...one of the covers is gone over the large pulley, and the bracket for the main gears is broken. I should be able to fab up replacements, at least once I get it under power and make sure everything is 100%.
So, here are my questions. Would it be worthwhile to go ahead and pull the gears to clean them, or just clean them in place? If I do go to that trouble of pulling the gears, should I go ahead and replace the bearings? What would be the most efficient way/method of proceeding? Thanks!
lordbeezer
Sep 1, 2018
184
Gonna be a nice lathe..the tooling you got with lathe will come in handy..looks like you have a 3 into 2 morse taper sleeve in spindle.good luck..
wa5cab
Downloads Moderator
Staff member
H-M Platinum Supporter
Dec 25, 2011
7,378
To answer your first question, no, The 9", 10" and 12" do not use the same tailstock. Most of the 10's and most of the 3/8" bed 12's do use the same 10D-6 tailstock base but for your particular 12", you will need the L4-5 Tailstock. Note that the later tailstock fitted to the 1/2" bed machines will not fit your machine.
As to whether or not it would be advisable to disassemble the entire machine for cleaning and inspection, I would say yes. As to whether or not you should replace part or all of the bearings and bushings, I can't say. You will have to evaluate those parts yourself.
FYI, Clausing Industrial, which was once Atlas-Clausing, still carries some parts for the Atlas lathes. But if your only exposure to prices is from the old Atlas or Craftsman catalogs, you may be in for some sticker shock.
Jason280
Mar 20, 2019
153
Thanks, I'll start looking for an L4-5 tailstock.
Any guesses on a year of manufacture? I've tried going through the sticky for dates, but haven't been able to figure it out.
eta: Found a really nice tailstock online, curious if I should go ahead and buy, or take a chance that I can get mine loosened up.
bama7
H-M Supporter - Silver Member
Jun 29, 2014
173
I would think you could persuade that tailstock to come apart. Nice little “love taps” ought to do it after a long soak.
jwmay
Dec 3, 2017
472
I'd remove the tail stock locking handle and assembly entirely, before tapping on anything. I don't want to come off patronizing, but I see that handle there, and would remove it, and inspect the mechanism first. It's just four parts. Two cylinders, a bolt, and that handle. And it's purpose of course, is to keep your tail stock quill from moving.
markba633csi
Apr 30, 2015
4,398
You can clean a lot of it in place, what I like to do is go down to the grocery store and pick up some of those shallow aluminum foil baking trays, the big ones, and slip one underneath the headstock. Then use solvent (Coleman camp fuel is good) and a small paintbrush and scrub away
Later you may want to pull the spindle and replace the belt, but do an initial cleaning first
Some of the smaller gears look pretty worn, check Ebay for those
Mark
wa5cab
Downloads Moderator
Staff member
Dec 25, 2011
7,378
I actually missed your first question and responded to your second one. The comparable 10" would be the 10F. However, the parts that you need, motor belt cover, change gear bracket and tailstock, are different between the 10" and 12". So that doesn't help you any.
Before I forget it, the first gear in the change gear train that you complained about the bolt not being the right length to lock it is called the sliding gear for a very good reason. It is supposed to be free to slide. If you could read the settings plate on your QCGB you would probably have figured that out. So put that gear back to the way that it was.
How do you know that your machine is a 101.07403 and not a 101.27440? The only difference between the two is that the former comes with a set of change gears and a left lead screw bearing and without the 101.20140 QCGB. And the latter has only the change gears that are on it and does have a 101.20140. There should be a nameplate on the right end of the bed above the serial number plate.
I recommend that you acquire a replacement change gear bracket instead of trying to make one. And it will have to be the one that goes with the QCGB and not the one normally on a 101.07403.
Your lathe was probably made in 1952 +/- 1.
As to whether or not to buy the tailstock that you found or to wait, you'll have to make that decision. I would remove the handle from the ram lock and also remove the anti-rotate screw and nut from underneath where the ram sticks out of the casting.
In Downloads, there is a PDF showing the chart on the gearbox. I think that it is in the threading section as it was scanned to go with the article telling how to temporarily convert the QCGB models to cut metric threads. The name of the article is something like "A 30 Second Metric Conversion.pdf". But you should keep your eyes open for that plate. Or you might still be able to buy it from Clausing. If they don't have the Craftsman one, ask about the Atlas one.
However, access to Downloads requires Donor status (minimum of $10 for a year) because Downloads is one of the significant monthly costs to keep the site running.
jwmay
Dec 3, 2017
472
I don’t know about all lathes of this brand, but on my two, you can’t remove the anti rotation screw until you’ve removed the quill. Mine both had a square end on the set screw, that just fit the key way in the bottom of the quill. Just if it doesn’t act like it wants to turn, stop and keep working on getting the quill out first. Otherwise you’ll break the anti rotate screw...ask me how I know. Wa5cab can probably tell you if that’s how they’re all made or not.
wa5cab
Downloads Moderator
Staff member
Dec 25, 2011
7,378
Oops. Thanks for catching that. You are correct. The screw has the end flattened and two flats either milled or ground on opposite sides so that it makes a key. And with the ram inserted , you can't rotate the screw more than a few degrees. I would however suggest loosening the lock nut and confirming that the ram is not stuck to the key and that someone didn't for whatever reason jam the key in the slot and lock it.
One other point. We are pretty sure that the bearing at the rear of the tailstock is pressed into the casting. At least no one that I know of has ever managed to remove a bearing. Otherwise, that is maybe what I would do and then try to press the ram out.
One other thing that you might try after soaking the whole thing for a while is to remove the handwheel and Woodruff key from the drive screw. Drill a flat bottom hole in a piece of 3/4" or 1" solid round aluminum to a depth of about half of the length of the exposed screw, and slide this over the screw. Drill a hole slightly larger than the ram through something like a 4x4 fence post. Set the post in a press, stick the exposed part of the ram into the hole, and use the press to try to break the ram free. Or as a last resort, use a hammer on the piece fitted over the screw. As far as I can tell, you have little to risk if it doesn't work.
Jason280
Mar 20, 2019
153
I thought I had posted this data plate earlier, but looks like I missed it.
Jason280
Mar 20, 2019
153
Never thought about Coleman camp fuel, I have several gallons of it (as well as kerosene) I can use.
I actually haven't really done anything with it yet, I just noticed that the gear would slide out of place sometimes (as it was meshing with the other gear) when I would turn the chuck. I still have quite a bit to learn about the machine, and what all the different levers/gears do.
I do appreciate all the suggestions, its definitely going to be a fun project. A friend of mine has suggested dumping the entire tailstock in his electrolysis tank, may help breaking down some of the crud.
jwmay
Dec 3, 2017
472
It’ll work. I did it once. But it really doesn’t look like it’s in that bad of condition. Anyways you’re the one who has it, so you’d know better than me.
jwmay
Dec 3, 2017
472
But...I think there are some aluminum parts, or zamak (which contains aluminum) which will be ruined(according to gurus on the net) if dumped in an electrolysis tank. So remove them first. I’m thinking that’d be the tailstock bearing housing, the handwheel, the quill locking clamp, and the clamp handle.
Jason280
Mar 20, 2019
153
I'll keep soaking it in penetrating oil, and maybe I can get it apart.
ELHEAD
Feb 13, 2014
322
Kerosene would be the better choice of the two. It's a lot slower drying than Colemans. I would check on the volatility of Colemans. I think you will find that is too flammable to be a safe cleaner, about like gasoline.
Dave
Jason280
Mar 20, 2019
153
I found an older Craftsman lathe manual online, and it actually mentions using kerosene.
wa5cab
Downloads Moderator
Staff member
Dec 25, 2011
7,378
Electrolysis has been said to degrade Zamak and aluminum. There are no aluminum parts on the tailstock (at least originally) but the handwheel and handle are Zamak, although that's easy to remove. The ram lock handle is but that's even easier to remove. And The two ram lock cylinders are *at least originally), and those are possibly the culprit to begin with. And even if they are not stuck, the lower one cannot be removed without first removing the ram. I don't know about the feed screw bearing. It may be, but I have never checked it.
wa5cab
Downloads Moderator
Staff member
Dec 25, 2011
7,378
OK. Then that probably explains the separate model number plate on the QCGB. I don't think that it is present on the 101.27430 and 27440, and I know that it isn't on the half inch bed later 12" machines.
I would put the manufacturing date as around 1951. And we have a few of the 101.27430/440's with nearly the same serial numbers, so the 101.20140 was probably also out. The guy who bought the 101.07403 could have saved a few bucks had he bought one of them to begin with.
Incidentally, your sliding gear should have a steel washer between the 16T and 32T gears of the sliding gear. It should have come as part of the QCGB kit. The early version 10" QCGB didn't have it originally but the 12" version was several years behind the 10" and should have. If any loose parts came with the lathe, look through them to see if he didn't put it on but kept it. Incidentally, the only time that you need to mesh the sliding gear with the 32T is when you are cutting 7.5 through 4 TPI threads. So if it isn't there, it won't cause much of a problem.
markba633csi
Apr 30, 2015
4,398
Dave: Kerosene works too, but it's so stinky. I like the faster evap of Coleman fuel, I consider it an advantage especially if used indoors
Some use paint thinner; it's about the same price as Coleman, at least in my city
M
Jason280
Mar 20, 2019
153
No steel washer, but I can't imagine it would be difficult to source.
What is the correct HP rating for this lathe, and any suggestions on a quick-style tool post?
pontiac428
Mo-Max
Apr 23, 2018
973
Jason, I don't want to startle you, but from the pics (and it is hard to assess from pics) it appears the bed is worn heavily near the head stock. Have you measured this, by any means available? It's hard to tell for sure in that light, but you might want to find out what the extent of the wear is, and if that particular wear point is going to be a problem for you. You can have the bed ground, and you can find another bed easily.
[7]
