- Dec 25, 2011
- 10,511
Based upon a report in the database that serial # 102826 was bought on 01/16/1974. I would place yours as made in early 1974. The date in the bed is the casting date. The Atlas MOLO says that bed castings were seasoned for at least a year before being finish machined. How much longer they might have been seasoned before machining or how long after that they might have been used, we don't know. Clausing lost or destroyed all of the Atlas production records.
The earlier machines with the different shaped gear and belt covers were made from 1936 until late 1957. Your machine is the final version. The version made from late 1957 until late 1967 are almost the same as yours except that they had the earlier pull-out knob to engage cross-feed, the earlier right lead screw bearing, no slip-clutch on the lead screw, and a few other minor differences. They also had serial numbers beginning with "00", not "10".
If you should ever have ocassion to pull the spindle, please report any dates found engraved on the spindle bearings.
