- Oct 18, 2015
- 25
Hey all,
I have an old Atlas 10F.. It uses the double v pulley part 9-428. It recently ended up spinning on the motor shaft. After realizing that the set screw is broken I had to use a 3 jaw puller and gently as possible removed it from the shaft. It marred the shaft a little but nothing serious.
However my question is that since this is such a recessed hole at an angle it doesnt seem that I have anyway to get a drill bit square against the set screw to try and drill it out.
Thought about purchasing a vice that rotates on an angle as my drill press platform is static and does not tilt..Saw a couple for sale and they were going over 100 bux.
Any ideas on a possible way to repair?
Thanks!
Sent from my VS995 using Tapatalk
Thanks!
