- Sep 15, 2016
- 17
when I brought this home It worked one time after pushing buttons until it turned on. Second time weeks later no luck probbaly programed wrong i check the wiring and changed V W so was wired up wrong first question did i blow up the af mini. So today I decided to try and get this working. Sent tweet to baldor in less than 30 seconds baldor sent me link to what i needed not what i asked for impressive. U is t1 v t2 w t3. So now i have it wired up Right now. The af mini 300 turns on and has 00000 accross the screen motor will not turn on. run nothing turn the dial nothing. Reading elsewhere here i see you have to program it. I have the manual but this is no help. If you try and search for what freq to set it up for that motor you get only links to the af 300 manual all of them in low res. So i have blown up the controler or dont know how to use it. This is first time i have used anything like that and can not find a intro or instructions step by step. unlike baldors customer suport the GE is a different story. MY only internet is this tiny phone with low res manual i am just stuck.
